SERIAL or TCP/IP remote control
Hello, it's been a while the UI series is out on the market, is it possible to have the control protocol for the ui series to integrate like the UI24 in a system controlled enviroment like Kramercontrol or Aten; the end result, is to give the user a very restricted enviroment with the simplest use case like change volumes and recall some snapshots from a button whithout the need to be using and accessing all the features of the mixer that are restricted to tecnician only.
thanks.
Luca.
  • TAICHEETAICHEE Posts: 266
    edited October 2023
    Bitfocus Companion has a module for Soundcraft Ui series.
    It can remote the mixer from streamdeck buttons and something message commands.
    You can set a batch command to the button of Companion then it will be called from TCP or UDP message.
    Set faders as absolute or relate value, mutes, recall cues, snapshots, something.
    https://github.com/bitfocus/companion-module-soundcraft-ui/releases
    This is to read to understand what you can do.
    Just install the companion. ↓
    https://bitfocus.io/companion
    It will get this module automatically.
