SI Impact Monitor sends question
Does the SI Impact console have more monitor sends than just the 1-14 buttons on the board? We really need a couple more than the 14? Thank you
  • TAICHEETAICHEE Posts: 269
    Sorry for that I am not the Si Impact user but I sometimes use Si Compact 32.
    My understanding since I read the spec of Impact, if you needed them as all mono aux, 14 aux is maximum. When you use stereo aux for some side fills or stereo IEM(s), 20 aux would be available logically because the aux 9-14 can be stereo aux. Then you will need external stage box for their physical outputs with using MADI connection because there are only 16 on-board output ports for 20 ( 8 mono + 6 stereo ) buses.
