Condenser mic
Stupid question I’m sure but i need help with hooking up a condenser mic. How do I get phantom power turned on for the condenser mic. I am adding it to an SI expression 3 board. Thanks for the help.
  • TAICHEETAICHEE Posts: 269
    The most simple step would be that select a channel, then tap the 48v button. Repeat this for all of condenser mic channels.
    When you would set up the console quickly, long press the 48 button first, then tap the select buttons which you want to turn on the phantom.
  • Thank you so much. I am new to this stuff and I appreciate the help.
