Ui16 date on recordings is wrong
I am trying to work out how the timestamp is set in the Ui16 for recorded audio files? It is consistently wrong by one+ day and I can't see anyway of setting the date or time in the settings. This is an annoying problem when trying to work out when a recording session happened. If it is from an online server then the server should take location settings. If it's held internally then where can you change it?!?
Answers
Same issue with the mighty Ui24R. System data and time is always July of 2016. I try to set current date under Settings but it does not stick. How to set to current date/time?
