Home Soundcraft User Forum Soundcraft General Discussion
UI24r Cascade
I have 2 UI24r in Cascade Mode. I need some direction how to patch AUX from the slave to the Master for separate monitor mixes
  • Hey JohnH.
    I have the same question.
    Hope some people can help!
  • TAICHEETAICHEE Posts: 269
    It is same thinking of main LR cascading. Masters of AUX bus should be cascaded as well.
    Set patching from MASTERS to CASCADE OUTS.
    For example, A1 of masters to the slot 1 of cascade outs.
    Then you patch same number slots to the channels at another unit.
    It is the section of CASCADE INS to CHANNELS.
    Rename these receiving channels like something you can't misread. And send the first one to aux1 with ±0dB, send the second to aux2 with ±0... same below.
    This makes it spends channel numbers as same quantities what you need numbers of aux.
    Even each unit has patchable 26 channels ( CH1-24 plus LINE IN L,R ) but it usually doesn't let you make a 52 CH mixer as kind of "26 + 26 = 52".
    When you want to cascade 10 buses ( 8 AUX and main LR ), it becomes "26 + 26 - 8 - 2 = 42" as 42 ch mixer.
    I recommend you to use more one channel for soloing another unit so it let you more minus one then it's a 41ch mixer with 8aux.
    When you want to cascade 10 AUX, total 12 buses, it becomes 39 ch mixer.
    Effectors are still individually. You can make same settings or preset for each 4 effects if you wanted same FX.
