Signature 12 / 12 MTK, Ableton, routing channels
Hi,
Is it possible with the Signature 12 MTK to routing like for instance 6 midi/audio channels from in Ableton to the 12 MTK and use the equalizer on the MTK to affect the sound of the midi/audio channel in Ableton?
Best regards,
Guido
Of course.
Recording those changes you make with the EQ is another step. That's called 'printing' using your Master bus inputs from 13/14 in your DAW. Create a stereo track in Ableton, set the input to 13/14, turn Monitoring off, arm and hit record.. play away with your EQ's..
