Home Soundcraft User Forum Soundcraft General Discussion
Ui24 wifi and ethernet connection problem
HELP!! Hi. I can not connect to my ui24
Not by WiFi (blue light won't turn on)
And not by cable. Totally locked out!
Also the reset doesn't work.
  • If you're experiencing connection issues with the Soundcraft Ui24R via Wi-Fi or Ethernet, several factors could be causing the problem. Common issues include interference or weak signal strength Learn More for Wi-Fi connections and incorrect IP configurations or faulty cables for Ethernet setups.
  • addisonjerry79addisonjerry79 Posts: 2
    edited February 20
    If you're experiencing Wi-Fi and Ethernet connection issues with the Soundcraft Ui24R, there are a few potential causes and solutions to consider. First, ensure that the router or access point is functioning correctly by testing it with other devices. If the Wi-Fi connection is unstable, try switching to a different Wi-Fi channel or using an external router for a stronger signal. For Ethernet issues, check cars if the cable is securely connected and try using a different cable or port.
  • TAICHEETAICHEE Posts: 269
    Unfortunately the original post was telling that blue light won't turn on.
    That blue light is at the middle of the WiFI icon printed, however it doesn't mean that it is WiFI activate lump.
    Actually that blue light is the system status lump.
    So, when the blue light won't turn on, it means the system fails boot up.
    Probably, his unit had defective in the 5V circuit fuse or something, I guess.
  • jamalaamirjamalaamir Posts: 6
    edited March 17
    The Soundcraft Ui24R mixer sometimes experiences connectivity issues with both Wi-Fi and Ethernet. Users may find that the built-in Wi-Fi network is unstable, causing dropouts or failing to appear in available networks. This can be due to interference, weak signal strength, or excessive distance from the device. If the Ethernet connection is also not working capcut pro download, it could be related to faulty cables, incorrect network settings, or a conflict with the router’s DHCP settings. To troubleshoot, users should restart the mixer, ensure firmware is updated, try different cables or ports, and verify IP settings for a stable connection.
