wifi connection of my ui24r aint working. i need to replace the panel,
hello.
the wifi connection of my ui24r aint working. i need to replace the panel, kindly help on how to purchase it.
thanks
  • TAICHEETAICHEE Posts: 269
    Why don't you send the unit to the official support repairing ?
    Otherwise why do you want to repair the WiFi?
    You may use the wired connection with external WiFi access point.
    ( If it was only the WiFi section issue. )
    Does the unit boot well but has a problem only with the wifi connection?
    Did you reset the unit?
  • MosieMosie Posts: 1
    Brand new user to this forum.
    I had a similar issue with my UI24; only one person could connect at a time. As it was a brand new unit Sweetwater replaced it under warranty. However, the support tech strongly suggested getting an outboard router.
    I know a router is easy to find, however can anyone suggest one that play’s nice with their UI, from personal experiences?
    Thanks!
  • gr121988igr121988i Posts: 1
    Buenas noches soy nuevo en esto, pero nuestra consola ui24r no nos deja conectar al wifi y se queda con las luces parpadeando.por favor ayúdeme
