Si Expression 1 output for live stream
Have read manual front to back on the Si Expression 1 but still struggling. Hope someone can help. Wanting to set up a separate mix other than the FOH mix to run to OBS for live stream. (I'll be going to an interface then into computer; the board does not have any of the optional cards, i.e, Madi, etc.) I'm assuming I can choose a stereo mix then designate two aux outputs and run those to the 2 channels on the interface? Then set these up post fader? Is that the best way to set this up?
Also, I'd like to have an audience mic in the live stream mix that I would not want in main mix. If set up as post fader, can I simply turn down the main mix completely for that mic and still bring it up in the live stream mix? I've rarely worked with live sound equipment and never used post fader before. Thanks in advance for any help.
Answers
  • bigrokbigrok Posts: 3
    Sound like a good solution!
  • RelledgeRelledge Posts: 3
    Thanks, bigrok. I was hoping this would work. I think the biggest part will be the learning curve with setting up the output routing. But the board seems fairly intuitive.
    Is it possible when running a signal post fader, to still set one of the channels to prefader? I know I'll need to have at least one channel for audience mics in the livestream mix, but that channel will need to be down in the main mix. Hope that question makes sense.
  • prawinprawin Posts: 1
    How can I load show in si impact through iPad because my display touch is not working so can you help me please
  • TAICHEETAICHEE Posts: 269
    Relledge,
    You can make the live-stream mix in a stereo aux ( e.g. aux13,14 ) bus as the post fader sends.
    You can stop the LR bus assign only of the audience mics.
    ( You use a stereo matrix for the venue PA via LR bus ).
    prawin, ViSiRemote doesn't handle the show system. Display touch is necessary.
