Error "403 Forbidden" using UI24r with external router
I'm having a time of it troubleshooting this "403 forbidden" error when using an external router with my UI24r. I'll clear the cache and other reset items and it'll connect and work for a minute then the error comes back. I've tried Chrome and Edge and it's the same result. Love the UI24R but this error is really hurting my experience as I have to use it connected to a LAN cable at all times. Without the external router I get too many dropout "reconnecting" errors.
Thanks for any advice.
Mark
If you're encountering a "403 Forbidden" error when using the UI24R mixer with an external router, it typically means that the device's network access is being restricted. This issue often arises due to incorrect network settings, permissions, or security configurations on the router. To resolve it, ensure that your UI24R mixer and router are on the same network subnet, check the firewall settings on the router, and confirm that no IP or MAC address filtering is blocking the UI24R exterminator melbourne. If necessary, reboot both the mixer and the router and try reconnecting. If the issue persists, consult the router's documentation for advanced settings or consider resetting the network configurations to default.
