Hi, I would like to identify the mixer in the picture.
It looks Soundcraft MFXi 20/2.
Frequency spec: 20Hz~20kHz(±1.5dB) Mic input noise (150Ω) : -126.5dBu THD+N(1kHz) : 0.01%(+14dBu) or less
Max input level (Mic in) +15dBu (Line in) +30dBu (ST in) +30dBu
Max output level (Mix out) +20dBu
Impedance (Mic in) 2kΩ (Line in) 10kΩ (ST in) 45kΩ <---- Probably a typo as 4.5kΩ
Cross-talk (CH MUTE) : 90dB or less (-∞ Fader position) : 90dB or less
EQ spec (mono in) HF 12kHz、±15dB、Shelving MF 150Hz~3.5kHz、±15dB、Peaking(Q=1.5) LF 80Hz、±15dB、Shelving
EQ spec (ST in) HF 12kHz、±15dB、Shelving MF 720Hz、±15dB、Peaking(Q=0.8) LF 80Hz、±15dB、Shelving
Phantom SW method : ALL channels
Dimensions (W×H×D) and weight : 688×94×405mm、9.3kg
Max input level
(Mic in) +15dBu
(Line in) +30dBu
(ST in) +30dBu
Max output level
(Mix out) +20dBu
Impedance
(Mic in) 2kΩ
(Line in) 10kΩ
Cross-talk
EQ spec (mono in)
EQ spec (ST in)
