UI16 questions
New member here and new owner of a UI16 with a few questions.
1) Is there any way to assign all the effects to a single fader? Was trying to set up my subgroups as drums, instruments, vocals, effects but didn't see a way to assign effects to a subgroup.
2) Would it be possible to use one of the aux sends as my main send to a small portable tower array and another aux for a subwoofer send? The reason for doing this would be so I could utilize the AFS on the aux sends. I'm sure it's possible but to be able to still use the subgroups would be the issue I see here.
3) Is there not a shelf option for the parametric EQ?
4 ) It looks like the only eq available on the aux sends is a graphic. Any way of utilizing the parametric EQ or HP LP filters on the aux channels?
Any help would be greatly appreciated. Thanks.
