Home Soundcraft User Forum Soundcraft General Discussion
No sound from mix A or mix B ui24r
Ok, so I have signal on the channel, master out meters. Mix A and Mix B are set at the 2 o'clock position. Should be getting output but nothing.
  • TAICHEETAICHEE Posts: 268
    Confirm the patching about the outputs.
    Ui24R has 12 bus lines as Aux (or MTX) 1 to 10, master L and R + solo bus.
    You should patch each of them to the physical output ports as AUX port 1-8 and ML MR (probably you described Mix A and Mix B) and 2 jacks of ST phones.
