Home Soundcraft User Forum Soundcraft General Discussion
Soundcraft Ui24R
G'day guys, I'm new to this forum.
I'm in a panic here trying to get my Soundcraft Ui24R mixer to behave.
I had it working beaut, then clicked the wrong thing onscreen, and now I cannot get back to the 'normal' Mixer window.
When I click the MIX/GAIN button, four sliders appear: FX1 REVERB, FX2 REVERB, FX3 DELAY, FX4 ROOM.
How do I get back to the normal Mixer window please?
I need to have this working for a session tomorrow.
Please HELP. Cheers, Ron in Western Australia
  • TAICHEETAICHEE Posts: 269
    You should post this question into the "Soundcraft Mixing consoles" category instead of the "Soundcraft General" category.
    Anyway you are showing only the FX return channels by clicking this in the screenshot. And the keyboard short cut is "W".
    Click it again or click the HOME button something.
    Or hit the W as that keyboard short cut. Esc would be OK.
    In the local setting Bigger slide out ON makes this style but you might see a bit narrower slide out according to your local setting although there is same button there.
  • Can I connect Yamaha PX5 amp's input to one of the ASF2 AUX XLR out of SoundCraft Ui24R ? Will there be any mismatch (like impedance, voltage level, etc.)? If I connect both as mentioned, will there be any noise or distortion to be expected? Or any other important information I should know before I connect both?
    I want more than 2 PX5 amp's (with Yamaha VXL1W-24 speakers) to be connected (for different rooms) and avoid feedback from all of these.
    What will be the best connection solution in this scenario?
    No problem.
