Home Soundcraft User Forum Soundcraft Stageboxes
Having problem with connecting Si Impact and mini stagebox 16i
Hi, I have used Si Impact console several years. And I need to expand my input channel so I just bought mini stagebox 16i.
As I know, it is automatically connected by just using cat5 cable without special settings. So I linked the devices with cat6 cable but failed to connect.
Detailed description:
-The firmware of Si Impact is up to date (2.1) and I tried factory reset following manual before the setup.
-The length of the cable is about 30m. (I've tried with shorter cat5e cable - about 2m can't make difference.)
-The green 'lock' led blink on both devices. But when I tried to find the stagebox in [Patching] - [Input Patch], failed.
-Also tried to MADI input 1-32 but it is also not working.
Did I miss something? What could I check more?
