Audio PC using ethernet cable
I got send audio from pc using usb cable, but sometimes this audio stop because have a long distance between soundcraft ui24r and the PC. Then I wanna use ethernet cable for that with adaptator ethernet/usb both sides, but didn't worked it. Is it possible to do that? If, how can I do?
There are many devices of the USB on Ethernet cable and and I heard that some of them will work well and some of them did not work due to the speed and stability but nothing is actually supporting.
You shoud place the computer upto 3 meter distance if it had USB-A. If it had USB-C, less than 2 meter must be better.
Then you may use 2 of cumputers so one is for placing near by Ui and another one can be on your table in a connection of the Ethernet cable upto 100m between them. You can remote that first one from the second computer by VNC, or you can use ethernet audio transfer softwares like Sonobus, DanteVia, and something.
Using an Ethernet cable for an audio PC ensures a stable and high-speed internet connection, which is essential for tasks like streaming, online collaboration, and downloading large audio files. Unlike Wi-Fi, Ethernet provides lower latency and a more reliable connection, reducing the risk of dropouts or interference that could affect audio production. This setup is particularly beneficial for professional musicians, podcasters, and sound engineers who require uninterrupted connectivity for real-time audio processing Fintechzoomnews, cloud-based storage, or remote sessions.
Using an Ethernet cable for an audio PC setup ensures a stable and high-speed internet connection, which is crucial for streaming high-resolution audio, downloading large sound libraries, and participating in online collaborations with minimal latency. Unlike Wi-Fi, which can suffer from interference and signal drops, a wired Ethernet connection provides consistent performance of Royal and lower ping times—essential for tasks such as real-time audio editing, live broadcasting, or remote music production sessions.
