Soundcraft LX7ii side panels unmount
Hello, can you please advise on how to remove side panels / carry handles from the Soundcraft LX7ii ? I need to do this to be able to fit the mixer on a stand between other boxes.
  • I have removed the three screws from the top panel but it seems that the side panels are held by something else beyond these.
  • OK, figured it out, the whole bottom casket has to be unscrewed and taken aside to allow access for internal screws that hold the side panels from inside.
  • To unmount the side panels of the Soundcraft LX7ii mixing console, begin by ensuring the device is powered off and disconnected from any power source to prevent electrical hazards. Place the console on a stable, flat surface with adequate lighting to work Snapchat planets comfortably. Using a suitable screwdriver, locate and remove the screws securing the side panels to the chassis—these are typically found along the edges of the panel.
  • To unmount the side panels of a Soundcraft LX7ii mixer, first power off and unplug the unit for safety. Use the appropriate screwdriver to remove the screws securing the Snapchat to the chassis. Carefully detach the panels without applying excessive force to avoid damaging the mixer.
  • MarviaMarvia Posts: 1
    Great tip on safely unmounting the side panels of the Soundcraft LX7ii mixing console! For more such updates and handy tips, be sure to visit Snapchat Planets (https://mysnapsplanet.com/ ) your ultimate guide for tech insights and more. 😊
  • To detach the Soundcraft LX7ii side panels, turn off and unplug the device. Place it on a stable surface with good lighting for Snapchat Planet. Use a screwdriver to remove the edge screws and lift off the panels safely.
  • laidd732laidd732 Posts: 1
    Hello, can you please advise on how to delta executor side panels / carry handles from the Soundcraft LX7ii ? I need to do this to be able to fit the mixer on a stand between other boxes.
