UI24R separate Master L and R, and link 2 channels
Hi, I have 2 small question that i include in this post
1) i see there is Master L R with only 1 Fader, can i work separately to increase or decrease volume from the web page, or shall i use the phisical volume trimmers on the front panel?
2) i know how to set 2 channels to 1 stereo, it's easy. How can i link 2 channels so when i adjust fader, the other fader follows the first?
Thank you so much, and Happy New Year 2025
  • TAICHEETAICHEE Posts: 269
    1) no. but slight yes,
    when you unlink the main master channels, only GEQ and COMP will be separated. so you can adjust the comp gain on either channels to make different level.
    2) a channel which you set link is the master channel then the next channel is the slave. The slave follows master except for the panning.
