A UI24R NÃO SALVA A CENA, OQ FAZER?
Olá,
sou novo por aqui e gostaria de uma ajuda em relação à minha Ui24R. Estou com um problema para salvar cenas: o console para ler o pendrive todas as vezes que eu o ligo, e ele volta para a versão de fábrica. Alguém pode me ajudar com isso?
Desde já, muito obrigado!
Answers
I don't know your language then I am not sure if I understood your question 100% with Google translation system.
Saving scenes don't have any relation to the USB pendrive.
However, this unit will be booted as the same status as you turned power off even if you didn't save scene ( = snapshot ).
You told that your unit will be reset every time then it seems that unit is in glitch. I recommend you to do the "FULL RESET" and update firmware again.
