UI24R in Hotstpot Mode
Good morning, i have a ui24r since some months and it works fine, i'm having fun with it. Usually it's configured via LAN (static IP) connected to a dhcp router and i rule the mixer with chrome using a Windows pc. Everything is ok, stati IP is 192.168.0.100
Today i had to use it in wifi so i configured ui24r as hotspot with a WPA password, and connected every device (tablet, notebook) to ui24r wifi, gateway 10.10.1.1 . i tried to log in into the ui24r page but i had problems with some clients:
PROBLEMS:
->Notebook (windows 10, chrome) works good :smile:
->Android tablet big display (about 13") works good (chrome) :smile:
->Android tablet small display (8") when i go into 10.10.1.1 ip it shows me the "more me" page, not the normal main ui24r home page! :-1:
->Android smartphone when i go into 10.10.1.1 ip it shows me the "more me" page, not the normal main ui24r home page! :-1:
So the last 2 devices in this list give me problems, i cannot see mixer home page. i only see "more me" page, but i never configured More Me in ui24r.
i tried to disconnect the first 2 devices, and select "phone" instead of "tablet" in the main ui24r first page shown, i tried every combination but i could not see the home page using the last 2 devices.
i don't remember if i tested ui24r with smartphone in the past, while ui24r was connected via LAN and static ip to DHCP router, so i don't know if this problem happens only in wifi hotspot mode.
does exist a way to bypass "more me" page and log in into the mixer's home page using android small display (8" or smaller) ?
Thank you so much for help
  • Got it from this video!!
    https://www.youtube.com/watch?app=desktop&v=MJdl-h1GblA&t=0s
    so, for beginners (as me) it's due to portrait mode on smartphone.
  • TAICHEETAICHEE Posts: 269
    Why don't you use same segment zone IP for static, even though the gateway was 10.10.1.1?
    You didn't tell about your system's subnet mask, but probably 10.10.1.1/128 (255.255.255.0) is used, I guess.
    This is not your issue but some devices what don't ignore the gateway might cause any problems.
    Howver, More me doesn't concern with IP setting. It's just rotation of the screen. Also as the window ratio for PC. Portrait size makes it to more me style. You can turn off this feature in the local setting window.
