Home Soundcraft User Forum Soundcraft General Discussion
Internal Hotspot repeater\extender
Hi my Hall audio installers have configured the halls ui24 unit by using a wifi repeater as the ui24 unit is locked in a audio cabinet within a locked cuboard as the hotspot was very unreliable
I suggested the router be connected via the units lan port but they say the repeater/extender solution will work fine please advise
  • TAICHEETAICHEE Posts: 269
    You are right.
    I recommend to use wired LAN.
    Ui24R
    Network SW --------- Wired PC controlling
    External wireless access point ( 5GHz or 6GHz )
    ( Probably this is what you are calling it as the router.)
    Wireless repeater works but it has risk.
    Not professional thinking.
    Let them stop it.
    Change that installer company, if it is possible. Not trustable guys. ( May be an electrician company instead of audio companies. ) Anyway kick them.
