Ui24 Aux bus recording
I will be using the Ui24R for a conference where they have their own sound system for someone who is speaking and I have a band that I will mix using the Ui24R L,R, out to two of the sound system mixer channels. However, in addition to this, I need to record the person speaking. I was going to put a lavalier on the person speaking but I don't want that on the main L and R going to the sound system. So my thought was to just mute the person's channel and then bring it up on the Aux bus. What I need to know is this: Can I record just the Aux bus to the REC thumb drive. If so, how do I do the routing? I know this is a little complicated,but any help would be appreciated. Thank You!
  • TAICHEETAICHEE Posts: 269
    Ui24R has several recording functions.
    The most easy one is the 2 trk recording to thumdrive, but it only records main LR sounds.
    If you want it, just you can run your PA from any of 2 linked aux instead of master LR, right?
    And the main LR can be for recording purpose only.
    Or, multi track record function will record each channel.
    So just you can record that lavalier mic channel.
    It will be pre processing audio ( post AD convertier direct out ) .
    DAW record function will record each input and some master buses.
    You can record aux bus as well.
    Anyway you can do whatever.
  • jrennajrenna Posts: 8
    An interesting idea to mix the band with the 2 linked Aux buses. I may try that one. I have never hooked up a DAW with this unit but I may explore that as well.
    Thanks for your input.
