Using Duet Modules
                    Hi,
Got another newbie question, I'm trying to use a Sharp TV module that I got from amx.com. But I'm not sure how to execute controls within that module. I created a virtual device that is passed into the module. So for power I'm thinking to turn on channel 27/28 for the virtual device, but I'm not sure how to do something like setting the channel to 901. I didn't see any documentation from the download page, so I'm kinda confused at this point.
Any help would be appreciated,
Download the .zip and not just the .jar - the module Interface Document is found within the .zip and it explains every control point contained within the module.
This should work...
I think i'm not using those channel correctly or i use it at the wrong place in my code.
where should i use those channel. i have a variable and i want to match that variable to the channel 255.
the way i use it is:
I'm sure i'm doing something wrong it look like the system slow down when i uncomment those line code.
Try something like this instead:
channel_event[vdvSharp1,255]{ on:{dvSharpPower=1} off:{dvSharpPower=0} }
