Home AMX Technical Discussion
Using Duet Modules
Hi,
Got another newbie question, I'm trying to use a Sharp TV module that I got from amx.com. But I'm not sure how to execute controls within that module. I created a virtual device that is passed into the module. So for power I'm thinking to turn on channel 27/28 for the virtual device, but I'm not sure how to do something like setting the channel to 901. I didn't see any documentation from the download page, so I'm kinda confused at this point.
Any help would be appreciated,
  • HARMAN_ChrisHARMAN_Chris Harman Integrated Technologies Group (ITG) Posts: 327
    javedwahid,
    Download the .zip and not just the .jar - the module Interface Document is found within the .zip and it explains every control point contained within the module.
  • javedwahidjavedwahid Junior Member Posts: 37
    This is exactly what I was looking for, Thank you
  • pcuserpcuser Junior Member Posts: 7
    PULSE [VirtualDevice,27]
    This should work...
  • RaphayoRaphayo Junior Member Posts: 111
    How do you use the feedback from channel 253,254,255
    I think i'm not using those channel correctly or i use it at the wrong place in my code.
    where should i use those channel. i have a variable and i want to match that variable to the channel 255.
    the way i use it is:
    DEFINE_PROGRAM
    dvSharpPower = [vdvSharp1,255]
    dvSharpWarming = [vdvSharp1,253]
    dvSharpCooling = [vdvSharp1,254]
    I'm sure i'm doing something wrong it look like the system slow down when i uncomment those line code.
  • TonyAngeloTonyAngelo Code Monkey Posts: 315
    Raphayo wrote: »
    DEFINE_PROGRAM
    Try something like this instead:
    channel_event[vdvSharp1,255]{
       on:{dvSharpPower=1}
       off:{dvSharpPower=0}
