Change port 10500
Hello, How can I change this port in NI-700 (firmware v.3.12.335) The manual says it?s possible.
This is a 2-step solution.
Step 1:
In the html files converted by TPDesign3, you'll find an html file which has the same name as the TPD3 file (MyPanel.tpd -> MyPanel.htm). Open this htm with an editor and modify the following line Value is the port for G3 WebControl.
Download the modified file manually to the master by ftp into the corresponding folder.
Step 2:
One of the files generated by html conversion of TPD3 is named wdm.conf. Open this file with an editor and modify the following line: Use the same number you have defined in the "MyPanel".htm. Save the file, and download it manually to the corresponding folder on the master by ftp.
That's it.
I have modified both files but it don?t work fine. The java logo is running and the application don?t start ??????
v3.16 Build 200 is required.
What version of Java are you using?
It's recommended to use J2SE v1.4.2_04 JRE or higher, we use _12. Link: http://javashoplm.sun.com/ECom/docs/Welcome.jsp?StoreId=22&PartDetailId=j2re-1.4.2_12-oth-JPR&SiteId=JSC&TransactionId=noreg
It may work with Java 1.5, but the TPD3 jar files are designed for 1.4.2.
If you use a Duet master (firmware v3), it may be required to enlarge the Duet memory.
Check by terminal or telnet:
Netlinx Studio 2.5.0.163
Tpdesign 3.16 b200
Java 1.5.0_09-b03
Duet Memory set to 12M
On my PC here I use 1.5 now and it works fine, but maybe it does because I had installed 1.4.2_12 in the past and then later installed 1.5 over 1.4.
I can?t change port 10500 ... !!!!!
