Change port 10500
Hello, How can I change this port in NI-700 (firmware v.3.12.335) The manual says it?s possible.
  • Marc ScheibeinMarc Scheibein Junior Member Posts: 677
    This is a 2-step solution.
    Step 1:
    In the html files converted by TPDesign3, you'll find an html file which has the same name as the TPD3 file (MyPanel.tpd -> MyPanel.htm). Open this htm with an editor and modify the following line
    <param name="connectport" value="10500">
    Value is the port for G3 WebControl.
    Download the modified file manually to the master by ftp into the corresponding folder.
    Step 2:
    One of the files generated by html conversion of TPD3 is named wdm.conf. Open this file with an editor and modify the following line:
    PERSIST_SRV_PORT 10500
    Use the same number you have defined in the "MyPanel".htm. Save the file, and download it manually to the corresponding folder on the master by ftp.
    That's it.
  • acalderon@acerc[email protected] Junior Member Posts: 9
    Step 1:
    Step 2:
    That's it.
    I have modified both files but it don?t work fine. The java logo is running and the application don?t start ??????
    What TPDesign3 version are you using?
    v3.16 Build 200 is required.
    What version of Java are you using?
    It's recommended to use J2SE v1.4.2_04 JRE or higher, we use _12. Link: http://javashoplm.sun.com/ECom/docs/Welcome.jsp?StoreId=22&PartDetailId=j2re-1.4.2_12-oth-JPR&SiteId=JSC&TransactionId=noreg
    It may work with Java 1.5, but the TPD3 jar files are designed for 1.4.2.
    If you use a Duet master (firmware v3), it may be required to enlarge the Duet memory.
    Check by terminal or telnet:
    >set duet mem
    Duet Memory: 10M
    Enter new Duet Memory size (between 2M and 36M):  10
    Duet Memory set to 10M
    >set duet mem
    Duet Memory: 10M
    Netlinx Studio 2.5.0.163
    Tpdesign 3.16 b200
    Java 1.5.0_09-b03
    Duet Memory set to 12M
    I think Java 1.5 is the problem. If you don't need 1.5 for another application, I recommend to downgrade to 1.4 (not necessary to uninstall Java 1.5 before).
    On my PC here I use 1.5 now and it works fine, but maybe it does because I had installed 1.4.2_12 in the past and then later installed 1.5 over 1.4.
    ok, i will try it
    With Java 1_4_2_12 fails too.
    I can?t change port 10500 ... !!!!!
