Tpd4 V2.7
x45polaris
Can't get v2.7 to load on my desktop, and on my laptop it won't connect to my NI's
Any Ideas?
Any Ideas?
...ever since installing 2.7 I've been getting the following error on a regular basis (several times a day) when running TPDesign:
"Runtime Error, R6025 - Pure Virtual Function Call"
These are the details I get in the error report:
"AppName: tpdesign4.exe AppVer: 2.7.0.545 ModName: uxtheme.dll
ModVer: 6.0.2900.2180 Offset: 00001531"
After that, the Microsoft "Dr Watson postmortem debugger" attempts to deal with the error and also crashes, lol.
8-/
One of them is if you select a button and then go to the text properties for it, you no longer get a non printable char for LINEBREAK if you have forced one with <CTRL> <ENTER> in this field.
ie to write the words 'dial call' on two lines in a button, the text box property used to look *something* like this:
dial▌call ...and it would show up as:
dial
call
in the button....now its just:
dialcall ....in the property box yet the button manages to still display the two lines.
The unicode editor still shows the LINEBREAK chars.
Not so simple to work with actually..
I don't use NS to load panels, I use TPD4. While I am in development or touch-up mode, I'll have both running with all the appropriate files loaded. I freqently will update a panel, then update code on the master, forgetting to disconnect TPD4 first. This never used to be a problem; TPD4 just notified me that it lost the connection. Now, it crashes about 80% of the time when I do that. Whatever they did to "fix" connection issues in fact made them worse.
