Home AMX User Forum NetLinx Modules & Duet Modules
DBX Zonepro 1261m
Just a quick question. I am using the module off the zonepro site and i am trying to figure out controlling zone volume. What is the protocol in the documentation that I need to do to control volume output in each zone. Basically what I am trying to accomplish is having a single volume page that shows the volume. based on the way i am reading it the module only does this for two zones. It is my first time using the box so help is greatly appreciated.
  • Jorde_VJorde_V Posts: 393
    bneal wrote: »
    You can control each output volume. You control the channel (1-6) (mono channels). So say zone 1 is stereo, you'd have to link the two in DBX using a RS232 to adjust the settings. Then you would need to change volume for channel 1.
    So to change 'zone' 1 you need to send: "'LEVEL=1:O:output_number:level"
    So in this case it's: send_command vdv_dbx,"'LEVEL=1:O:1:',itoa(level.value)";
    Good luck.
  • I have programmed to control dbx 1261m over LAN for last 3 days and was able to trigger commands to the dbx from emulate device and control a device options. But dbx has stopped communicating to the AMX from yesterday. It does not responce to the commands. I tried using both serial and LAN. I observed it gives error code 11 and the port Status shows Offline in diagnosis window. Please help me what this error mean and what I can do it fix it.?
    please Note I am able to access dbx zonepro in Zonepro designer software.
    Do you see responses from serial when you turn on notifications in Studio? Just trying to get to a quick foundation on what we are working with.
