NS3 Crashing Like Crazy
JeffJeff Posts: 374
I've been running NS3 now since the day it was released. It has now crashed on me at least once every day. It doesn't appear to care whether it's my Vista system or my XP system, it just crashes.
Sometimes I'll get an error when it boots up, that it couldn't locate certain protected word files, so highlighting might not work. For about 3 or 4 minutes, only about half of the words that should be highlighted are, and then it will crash.
More often, though, I'll start it, it will load the workspace that was previously loaded, and crash before finishing the load. The only way to stop it is to move that workspace and all the files that were previously loaded somewhere else, so it can't find them. I've disabled the restore workspace on startup, but now I'm taking away features I had so that I can use it.
This was especially frustrating yesterday while I was trying to make one little change to a system, with a client standing over my head telling me I should've been out of his building 20 minutes ago, so he could go home, and I couldn't get NS3 to load. Rebooting the machine did nothing.
Is anyone else having these problems? I had no issues with the upgrade process on either machine, and yet I can't help but think this software isn't ready for prime time.
J
«13
    I have not experienced any lockup or crash problems with NS3. It sounds like there is something corrupted in one of the files from the workspace. Have you tried to uninstall completely and reinstall NS3?
    Also, on a long shot, are you running cafe duet? The only problems I had with NS2.8 came from an update on the Cafe Duet side.
  • JeffJeff Posts: 374
    No, I'm not running Duet, and it has happened on multiple different workspace files.
    I haven't done a full uninstall/reinstall yet, that's the next step but I figured I'd check and see if anyone else had already found the answer first
    J
  • Its crashed a couple of times on me over the last few days - seems to be co-incidental with clicking the file transfer icon.
    No big deal - seems to happen when its a good time to go for coffee anyways.
    I had a few issues with one of the beta vfersions. However, that seems to have been fixed. The official release has not crashed on me once. Touch Panel Design, however....
    Yes, had it crash 2-3 times this morning doing a simple compile.
  • annuelloannuello Posts: 294
    I noticed that mine crashed when I had more than 2 instances of it running. It seems fine with only 1 or 2 instances of it open.
    Roger McLean
    Swinburne University
  • DavidRDavidR Posts: 62
    ive had it crash if im scrolling or click things real fast.
    definetly crashes more than ns2, so much more in fact I was looking for posts regarding this earlier in the week.
    Given this, why is it exactly that we can't run NS2 at the same time?
    I LOVE a lot of the features of NS3 (mostly the better integration of include files, since I have 6 include files I use in every project that have a lot of my definitions in them, so now they're showing up in autocomplete and getting highlighted correctly), but this is my business. I can't spend an hour on site troubleshooting NS3 because it's not a solid piece of software.
    Has anyone rolled back to NS2 yet? Is it a pain?
    J
    I've had it crash once when a network connection faltered and dropped. It would seem to have inherited the same lack of grace in dealing with connection issues that TPD4 has. Time for a new IP library ...
    Jeff wrote: »
    J
    No, rolling back to NS2 is trivial, doesn't even lose your settings. I've rolled back and roled forward again, both without incident on XP SP3.
  • Duncan EllisDuncan Ellis Posts: 172
    NS3 Crashes
    I've had similar problems with the workspace issues. NS3 will just not load a workspace but will load single files.
    I do quite a lot of work remotely and it seems to be worse when your connection address is a WAN address - but this may just be coincidental....................
    Just to say - no crashing / locking problems here. Just the typical "it's looking for bad IP" timeout, but it eventually returns.
    Vista & XP (SP3)
    jjames wrote: »
    Vista & XP (SP3)
    I have had the 'looking for IP' hangup that eneded in a crash now two times.
  • matt95gsrmatt95gsr Posts: 165
    So,
    I've been busy for the last month or so spending most of my time working on non-AMX stuff and thus not spent much time with NS3. Now that I am running full-speed on some AMX projects, I am seeing that NS3 is exhibiting more problems than I originally thought. It seems that Studio wants to crash _every_ time that I open it. On average, it takes 4 tries to get it to open and stay open. And then, about every 3rd or 4th time that I save (or compile) it crashes again. It does actually save, but then crashes anyway. Have also seen the same thing when opening or closing workspaces. This was happening in the field last week on my laptop (XP SP3), and is now happening on my desktop (XP SP2). It's becoming extremely frustrating. The bad thing is, with it crashing so much it makes me want to save more often to protect from lost work, but the more I save the more it crashes. Are others seeing general crashes like this that aren't associated with file transfers, multiple workspaces, etc or is it just me?
    Experienced my first
    I've not had the issues you've been experiencing, but did experience a crash when I tried to open up a workspace when I had another instance already running. But it only happened once and am not too concerned about it. This was on my Vista SP1 machine.
  • bwestlakebwestlake Posts: 82
    Vista 64 bit
    NS3 crashes at least 2x per day. AMX says they don't support Vista 64 but NS2 has worked flawlessly on this machine for the last year. From what I'm reading here I don't think the crashes have anything to do with my Windows version.
  • ColzieColzie Posts: 470
    I have been using NS3 every day (almost all day) since the day it was released (a few weeks ago?). I have only had it crash one time.
    You guys must be doing something wrong ;)
    I think most of the crashes are linked to the IP library. If you have a solid connection, no problem. If the connection flakes in the middle of anything, it crashes and burns instead of dealing with it gracefully. TPD4 has been that way for a long time. They really need to license better libraries.
    I'm really perplexed by the whole thing. I've been onsite for the last 2 days, experiencing the exact same things on my laptop that I was dealing with on my desktop this past weekend. It doesn't seem to have any ties whatsoever to my connection, especially given that I wasn't connected to a master at all from my desktop and have been connected some of the time this week. Still seems to be tied to saving/compile operations (of which, I assume is probably the save before compile portion of the compiling causes the issue). Happened also today when I copy/pasted a 4-line piece of code twice. Still seems to be about every 4th save that crashes, and it takes 3-4 attempts to reopen without crashing. I'm going to continue tomorrow shutting things off to see if I can find a conflict somewhere, but I'm not sure I'll find anything.
  • NS3 Crashing on Startup
    Glad to see it's not just me for a change.
    NS 3 sometimes crashes as it starts up - it appears to be opening and processing the files that were last open.
    If this is of any use to anybody the error log came up with the following;
    AppName: nsx.exe,
    AppVer : 3.0.0.315
    ModName: msvcr71.dll
    ModVer: 7.10.6030.0
    Offset: 0000426e
    Exception Code 0xc0000005
    Windows NT 5.1 Build 2600
    Perhaps change your settings so it does not open the last workspace. Not a fix I know, but at least it might help save some time and frustration. Trying to launch a program 3 or 4 times can make anyone go crazy.
    I take back my theory about the crashes being connected to the IP library ... well, I think I do at least.
    I was working all day yesterday without a single crash. Today, it seems to be crashing every five minutes, whether I am actively editing, or in another application (as in reading an RS-232 spec in a PDF viewer). Nothing was lost except the workspace changes, and what do you know, I have autosave set for every five minutes. So, it's actually saving the open file, and crashing immediately after. It doesn't seem to happen all the time, but that does seem to be the trigger. Interestingly enough, I made a change in the workspace by adding a UI file that had a new revision. That particular workspace change was saved because I explicitly saved the workspace afterward ... but, the file path was messed up after the crash. It lost the project subfolder and was looking for it in the main folder ... even though it was entered originally by the "Add existing file" method. I wonder if the crashes are related to autosave reacting badly to bad path information in the workspace.
    DHawthorne wrote: »
    Not to "discredit" your thoughts, but just thought I'd mention that I knowingly work with bad workspaces from time to time (old workspaces created by my boss referencing IR files lost in a reformat), and I also have auto-save on and set to five minutes and haven't experienced this problem.
    I do on occasion have a crash when opening a workspace, but immediately opening it up after the crash, it works fine.
    I've definitely had the same workspace crash NS3 four or five times in a row as I try to open it, and then on the 6th try, it'll randomly work fine.
    I've also had it crash when closing a workspace, oddly enough.
    J
  • excaliburexcalibur Posts: 7
    I've experienced a lot of crashes while merely saving files. Ctrl-S... crash! At least it did save the file before crashing. Occasionally it will crash upon opening, particularly if my last workspace had a lot of open files. Glad to see find and replace is at least mostly fixed...
    There may be a timing issue involved as well. My computer is getting old and slowdowns are noticeable. The newest TPD4, especially, seems to take just about forever to save it's temporary files before sending a panel (and it drives me insane waiting for it). It could be the crashes are less frequent on quicker machines, or perhaps not there at all. That's another pitfall for all developers ... the tendency to have new and fast machines, where the user may be somewhat behind.
    I can say this much, between TPD4 and NSX3, it's getting so that I wait more for the computer than actually work on it. My boss doesn't want to upgrade as long as it functions at all (due to the economy), so I'm kind of stuck unless I buy my own (not likely, not unless I go freelance).
  • jsc5225jsc5225 Posts: 1
    Reserved word problem
    I have had it crash several times, but the most frustrating thing that happens (at least once or twice a day) is that after a compile, I'll get an error message "Reserved word (.rw) files could not be loaded. Keyword highlighting will not function properly. Check Installation." with an OK button. However, as soon as I press OK on the dialogue box, I get the same error message, so I can never continue work or quite with out going to the task manager and shutting down from there.
    Scott
    bleh. I've gotten that error a few times. Haven't had it repeat like that.
    So the real question is . . . . when's the next build coming out?
    Also, to those of you who beta tested, did this stuff show up then? Or is this new? I don't understand how this got released past beta . . . . .
    J
    Jeff wrote: »
    J
    It's pretty near impossible for a relatively small subset of beta testers to duplicate the variety of circumstances that are going to exist in the field. I would vastly prefer an open beta, but even that may not catch everything because people have to use this to make a living, and might hesitate to install a beta version ... so it's not going to be the same as release. But I do have to agree that I also expect a release not to have these kinds of issues.
  • Crashes?
    First, on behalf of AMX I am sorry for any problems that are occurring and thank you for your continued participation in the forums.
    My personal experience has been no crashes on a year old Dell laptop. I did my current install on top of a beta v3.0 install on top of v2.8 which was installed on top of v2.7. That is as far as this machine goes back. I am wondering how may previous installs some of you are running that are experiencing issues.
    Since this thread is not growing very much, can we assume most users are having pretty good luck?
    I suggest you continue to pursue any issues directly with AMX tech support. They just might have some good ideas to try. I would also consider your number of open applications verses processor speed and available RAM.
