R4 has Insomnia
in AMX Hardware
I have a brand new R4 in my office that won’t stay asleep. Every 30 seconds to 3 minutes it wakes up all on its own. It doesn’t matter if the R4 is in the cradle or laying flat on a desk and it doesn’t matter if the gateway is powered on or not or if any NI masters are powered on or not. The darn thing just keeps waking up. Anyone else experience this? Maybe the tilt switch is flaky?
The continual flash from the screen and high pitched squeal from the backlight is getting on my nerves so my only option right now is to let the battery die.
I haven't seen this but have had customers complain about it, waking them up in the middle of the night. Try keeping in your hand while it boots, and then putting it in the cradle once it has booted. I believe the touch sensor calibrates to your hand after a reboot, and so if it boots while in the cradle, then the touch sensor is too sensitive and can wake up randomly.
For some reason only some of the R4s I have used have this issue, and I don't know why. Perhaps it only needs to be done after a firmware upgrade or some other variable. Perhaps there was a hardware version that had this problem and it was fixed. I have mentioned it to clients and they seem to be able to do this easy workaround if the remote exhibits this issue without too many complaints. It would be nice if AMX could figure it out and provide a solution though.
Thanks for the suggestion Paul. Rebooting it my hand might have slowed down the frequency of wakeups somewhat but it’s still exhibiting the same issue. I put a stopwatch to it before and the longest it slept for was about 3 minutes but most of the time it woke up in less than 1 minute, sometimes less than 30 seconds.
Here are the sleep times after rebooting in my hand:
05:54
01:53
00:34
03:10
00:53
01:14
02:58
00:26
00:37
03:37
04:24
00:32
01:21
02:20
I don’t see any pattern to these continual wakeups but it’s definitely still having issues staying asleep.
What are the sleep settings you are using? Is the sleep on display timeout used?
Display timeout has always been 10 seconds.
The sleep settings for the test I posted was 5 minutes and Sleep on Display Timeout was disabled.
I’ve tried different sleep settings before - 0, 3 minutes, 5 minutes. If I use Sleep on Display Timeout the wakeups seem to occur more regularly either every 90 seconds or so or 3 minutes. Hard to tell though and I’m getting bored sitting here with a stopwatch timing it.
Try 20 seconds and sleep on display timeout set to on. This is what I had set when mine were doing the same thing. It might not make any difference but its obviously a hardware/firmware bug, since this can happen even without being connected to a system.
My R4 is set to timeout at 30s and sleep at 3m.
Nope,still doing it. The first wakeup happened only 13 seconds after the 20 second timeout with the sleep on display set to on. Now it’s waking up with under a minute of sleep. It’s seems so sporadic. I'll try rebooting again in my hand with these settings.
I had a different R4 here in the office early this year and I don’t remember seeing the problem with that one.
Yeah, it may have to go back from whence it came.
I tried the 2 handed fidgety reboot with the settings that Paul gave me and it woke up 20 seconds after the timeout. Then it went to sleep for 4 minutes and I thought maybe it was fixed. But then after the 4 minute sleep it woke up and stayed awake for a full minute even though it has a 20 second timeout so I think it woke up while it was awake and delayed the sleep. Argh...
Thanks for your input guys. I'm done messing with it.
Yeah but Joe's OP said he tried w/o gateway and w/o master, the R4 all on it's own which excludes all those possibilities but vibration.
I don't think that is true, but if it is, that's poor design. Having an R4 light up in the middle of the night in a bedroom is just stupid, annoying and unnecessary.
Try pulling the battery out for 5 minutes and then hold the remote touching both side metal strips until it is completely finished booting up and let us know.
That is the solution that I have used when I had a few customers complain about their R4s turning on by themselves and I have not heard the customer complain about the issue since.
edit: For what it's worth... The next 4 big jobs will be using either URC or RTI remotes talking to their respective processors and RF antenna networks and shooting 232 or IP commands to AMX, so take that for what you will (this decision was not based on the cost of the remotes at all)....
Hopefully this issue gets resolved in a future firmware release.
After further review the call on the field has been reversed.
It was okay for a few hours but now the R4 is back to its old tricks and it won’t stay asleep.
I was hoping for a firmware fix but it looks like it's going to be an RMA.
I didn't get around to opening the box until several weeks after I received it.
I think there's a hotfix available for the gateway as well - might want to call into tech support, explain your problems and ask them if the hotfix would correct the issues.
I'll plug my desktop R4 back in, upgrade if necessary and watch it to see if it is still acting up.
