Where is the sampling rate setting?
I cannot find anywhere telling about changing sampling rate, 44.1, 48 or etc. I hear someone said about working with DAW and it could change in that situation.
If there is any answer, thank you.
Sam.
Sam.
for Ui24R, thanks, I couldn't find the edit function.
Greetings Sammtri - did you ever receive any response to this question? I ask as I too am recently trying to figure out how to adjust the sampling rate from 48/24 to 44.1/24...
There is NO sample rate setting . Ui24R is fixed at 48K. You can adjust the bit depth under Settings for the stereo record and you can change formats on The Multitrack from WAV or FLAC with 2 choices of bit depth.
