UI24R not maintaining previous settings on restart
My ui24r resets to factory when I power down and restart for the next show. Shows and screenshot settings are not recalled either, even though they still show in the menu. The usb drives don't seem to be active as nothing shows nor appears in the playback menu. Finally, I don't seem to be able to do a proper factory reset as once I try I'm not getting the 10-15sec flashing blue light... Are there any suggestions or recommendations?
Do you have any solution? i experienced the same problem
Same problem here. Any solution?
Do you save the show before you power down?
I save the show both internally and to a usb stick
sim problem !!!!
Just Update firmware again
any solution?
