Denon Blu Ray3800BBDCI
I am having issues getting control over this BluRay. Has anyone ever controlled on of these? If so could someone some sample code?
I tried the Include file that is floating around the forums with no luck.
TIA
TIA
http://amxforums.com/showthread.php?t=3956&highlight=Denon&page=2
Some where in the middles of this page TonyAngelo posted a module for this which is what I've been using. Its complete with open com module/code so you can tailor it for your future needs.
I am using a modified version of it as well, as so far so good, thanks Tony!. I have found one bug and that is when the Blu-ray outputs Dolby TrueHD, the module seems to think its Dolby Digital. I am sure its a minor issue, but I haven't had time to look into it.
Can someone verify that I have the baud right?
That looks fine. Don't forget you have to send it a status request command which is button 307 I believe in Tony's module.
Yes, I think in later versions I send this command any time I receive a power-on message, but it may not be that way in the version I posted. It is an include file though, so you can change it to suit your needs.
DATA_EVENT[dvDenon3800] { ONLINE: { SEND_COMMAND DATA.DEVICE,'SET BAUD 9600,E,8,1 485 Disable' SEND_COMMAND DATA.DEVICE,'HSOFF' SEND_COMMAND DATA.DEVICE,'XOFF' stDenonBlu.PowerOnDelay=150 ON[stDenonBlu.CTS] [dvDenon3800,255]=stDenonBlu.Power } STRING: { STACK_VAR CHAR sMyBuf[50] WHILE(FIND_STRING(stDenonBlu.RxBuf,"$03",1)) // while there's an end of message byte in the buffer { sMyBuf = REMOVE_STRING(stDenonBlu.RxBuf,"$03",1) // pull out the message REMOVE_STRING(stDenonBlu.RxBuf,LEFT_STRING(stDenonBlu.RxBuf,2),1) // get rid of the checksum IF(LEFT_STRING(sMyBuf,1)="$02") // is this the beginning of a return message { GET_BUFFER_CHAR(sMyBuf) // remove the $02 IF(FIND_STRING(sMyBuf,'DVD-',1)) // is this a power on message? { // power msg parse STACK_VAR INTEGER nMyStart stDenonBlu.Power=1 // update variable stDenonBlu.StatusCode=0 fnDenon3800Update() nMyStart = FIND_STRING(sMyBuf,'DVD-',1) // find the start of the device name stDenonBlu.Name = REMOVE_STRING(sMyBuf,'BD',nMyStart) // pull out the device name WAIT stDenonBlu.PowerOnDelay 'Power On Wait' // unit takes 15 secs after power on to respond to cmds { ON[stDenonBlu.CTS] ***This turns on status transfers ---> fnDenon3800CmdSend(nDenon3800_StatusSend) // set to auto transfer mode } } ELSE // normal message { fnDenon3800MsgParse(sMyBuf) ON[stDenonBlu.CTS] } } ELSE { // not the beginning ON[stDenonBlu.CTS] SEND_STRING 0, '!Denon3800 Rx Buffer error: Cant find the start of a new message!' } } } }
