Denon Blu Ray3800BBDCI
ondrovic
I am having issues getting control over this BluRay. Has anyone ever controlled on of these? If so could someone some sample code?
I tried the Include file that is floating around the forums with no luck.
TIA
TIA
http://amxforums.com/showthread.php?t=3956&highlight=Denon&page=2
Some where in the middles of this page TonyAngelo posted a module for this which is what I've been using. Its complete with open com module/code so you can tailor it for your future needs.
I am using a modified version of it as well, as so far so good, thanks Tony!. I have found one bug and that is when the Blu-ray outputs Dolby TrueHD, the module seems to think its Dolby Digital. I am sure its a minor issue, but I haven't had time to look into it.
Can someone verify that I have the baud right?
That looks fine. Don't forget you have to send it a status request command which is button 307 I believe in Tony's module.
Yes, I think in later versions I send this command any time I receive a power-on message, but it may not be that way in the version I posted. It is an include file though, so you can change it to suit your needs.
