HOLD repeat times
Can anyone tell me how you set/adjust the rate at which a command is repeatedly sent from the HOLD action of a button event?
Not directly. If you really need that, launch a repeating timeline on the hold, and kill it on the release.
Yes. You can specify a 2 second hold time and then if it gets in the hold, turn on a variable that exists in a different hold event with a different repeat time. That should allow you to hold the button for 2 seconds and then repeat events at a different interval in the other hold event with the same channel number. Turn off the variable on the release.
I think this code is correct. Actually you would either need to change the repeat time to 1 or make sure every select active is a multiple of the repeat time used.
I prefer this way since HOLDs don't play nicely with arrays (can't fully rely on a GET_LAST in a HOLD.)
Will that work? Is holdtime guaranteed to be a perfect multiple of the repeat?
jjames wrote: True, I don't like anything that evalutes the button or TP in the HOLD event either for that reason and usually set the hold button and the TP that iniated it in the push event like: I then release it in the release event handler if everything matches.
If you're concerned about mutliple TPs you could create an array the size of the number of TPs and store the hold button for each TP in that.
I'll do one of two things to replace a HOLD event, and of course works fine.
If I need to do something once (eq. to HOLD[20]), I'd do something like this:
Now the above code is good for multiple panels to save a certain type of preset that all the panels share. If you wanted each panel to have it's own set of presets, you'd simply create the array, and have multiple CANCEL_WAITs & WAITs within a SWITCH/CASE or SELECT/ACTIVE situation.
For a repeating hold (eq. to HOLD[2,REPEAT]), I use Brian Clement's ramping volume timeline code, which essentially starts a TIMELINE with the PUSH and kills it on the RELEASE (as Dave had mentioned earlier.)
sn't it funny how the HOLD event almost always stirs up some kind of in-depth conversation where everyone jumps in? It seems the HOLD event itself isn't as perfect or easy as the PUSH & RELEASE.
I think the question is about the precision of the timing. When your hold time is .2 seconds, is it guaranteed that the timing will be precise to the ms? Perhaps that .2 second hold occurs at 201ms instead of 200 ms. Might be better to check for closeness rather than equality -- sort of like with a floating point number. (Never check to see if a floating point number is FALSE)
I don't really use holds that often and I don't think I have any holds using button.holdtime but it is an option and If one was to use it they would have to play with it and see if there are quirks.
jjames wrote: What do you mean? I know of no reliability problems using GET_LAST during a triggered event. I don't really consider HOLD a triggered event since its really just the result of a push that hasn't been released. So if you use GET_LAST on the trigger events (PUSH, RELEASE) I see no problems.
I just think there's too much hassle with the HOLD event. I don't want to have to manage variables and in the PRESS and RELEASE in order for something in the HOLD to work properly; I'd much rather remove the HOLD and just do it all in the PRESS/RELEASE. Just a difference in personal style I guess if it works your way as well.
Not enough cats for all the different ways to skin 'em.
I like holds for ramping volume on things like ClearOne mixers. Easy to understand, easy to implement, and it works well. Clearly, there are other methods.
I haven't found holds to be a hassle at all, so I guess I don't know what you mean. get_last has always worked perfectly reliably for me. You just have to be aware that it is a global function so that any touch panel will change its value but it will always return the correct value. If you need to store that info for hold events, then that is something you can do easily enough.
This is one topic that cannot be argued without showing examples how to get unintended results from your running system. Of course two users would never be operating two different touch panels at the same time, right.
If there is only one touch panel in a system, HOLDs work great. If you use multiple panels with device arrays then there is always the potential for problems using the GET_LAST() function within a HOLD...not a recommended coding practice. This is a difficult concept to grasp until you get burnt.
What's been said is that GET_LAST() should be used only in the PUSH or RELEASE and if you want or need to implement a HOLD the button value should be obtained from the PUSH and held in a safe place for that purpose. It's been suggested that a TIMELINE should be used but that has the same potential for erroneous results as does using the HOLD event since they both depend on the method you use to obtain the value for the button you wish to HOLD and or REPEAT. If done wrong either method's value can change by other events or user pushes. That's true even if you don't use a HOLD event handler and trigger your home brewed HOLD by a starting a timeline on a PUSH and killing upon receipt of a release.
Either method is as reliable as the other if done right but the HOLD is by far the easiest to implement.
Here's an example of getting burn with a HOLD event. This was part of a transport key section, to continuous send a FFWD or REW command to a DVD player or CD player. The problem came along when one panel was using the DVD player and another panel wanted to do the same thing with the CD player. (This is just the HOLD portion of the entire BUTTON_EVENT.)
The fix (back then with limited programming experience) was to create a BUTTON_EVENT for each panel for those two buttons. Having to do it 18 times wasn't fun.
As long as you're not obtaining your button number through a GET_LAST in a hold event there's really no difference. If you think about it you could use a GET_LAST in your timeline event and that would have the same potential for errors as a GET_LAST in a hold event handler.
So if you only use GET_LAST in the PUSH or RELEASE and then properly store the button number in a safe place either method will perform the same end result with equal reliability whether you use the HOLD or TIMELINE method. They're both good, the HOLD is just easier.
In this example every TP could initiate a HOLD on this device at the same time but unless it's something like an autopatch switcher and every user is on a seperate zone you going to have other problems to worry about.
Here is a code block that I put together that controls volume in multiple zones from multiple panels using TIMELINES instead of HOLD. It is completely scalable for as many panels and as many audio zones that you need.
The same concept can be applied to other repeating type Button Events.
Enjoy!
